Hello Guest it is November 13, 2026, 04:06:13 PM
Author Topic: Getting New Installation Going  (Read 61228 times)
« on: March 12, 2006, 06:30:09 PM »
I had Mach3 Turn running quite well last weekend, but the motherboard on that machine fried.
I got a new motherboard, processor, memory, hard drive, and got Windows XP Professional, just to make sure that the Windows XP Professional System Optimization Guide was 100% relevant.
I have gone through the Optimization Guide and did everything suggested, except for one thing.  On Step 9, when I tried to Update Driver on Computer to Standard PC, the DriverTest would not run.  Changing the driver back to Uniprocessor PC allows DriverTest to run to completion.  I had in Step 0 disabled ACPI in the BIOS Power Management Setup, so this shouldn't matter.
When I connect up to the lathe, velocity values that previously were fine now result in motor stalling.  I used to get 1450, now I can't get 1000.  I have tried both 25000 and 35000 kernal speeds, and there doesn't seem to be a difference except what the motor tuning dialog reports as the possible maximum.
When I slow the motor way down just to get it to work, the axes move, but I can hear a thudding on both axes that occurs roughly 3 times per second.  The frequency of the thudding noise does not change when I change the motor speed.
I am using Version 1.90.017.
Any advice on how to debug this would be appreciated.  Thanks.
Re: Getting New Installation Going
« Reply #1 on: March 12, 2006, 07:19:18 PM »
Just as a quick test please try running in Sherline mode..
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: March 12, 2006, 07:32:09 PM »
Assuming I didn't need to reboot or restart, there is no difference.
« Reply #3 on: March 12, 2006, 07:33:31 PM »
I think you need to restart... But I could be wrong...
www.machsupport.com
« Reply #4 on: March 12, 2006, 08:44:10 PM »
I set the Sherline 1/2 pulse mode, applied, okayed, reset, shut down, and restarted Mach3.  There's doesn't appear to be any difference.
« Reply #5 on: March 12, 2006, 09:10:38 PM »
Art should be back at it tomorrow :) I will tell him that we need to have his help.
www.machsupport.com
« Reply #6 on: March 13, 2006, 12:36:35 AM »
Thanks.  I'll really appreciate the help!
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #7 on: March 13, 2006, 10:26:07 AM »
Hi Guys:
  I suspect your timing is not good. Run the drivertest.exe. Are you sure its showing a line with no hugh spikes of timeing variation??
Thnaks
ARt
« Reply #8 on: March 13, 2006, 10:15:44 PM »
I ran DriverTest and waited for a particularly bad spike, then grabbed the screen.  This is what I got (except that the original Timer Variations frame was gray, not pinkish):
It's usually quite flat with little variation, more like this:
« Reply #9 on: March 13, 2006, 10:50:23 PM »
As best I can tell, there's not much else going on:
