Hello Guest it is November 13, 2026, 04:06:13 PM
Author Topic: Got My mill running :)  (Read 97622 times)
« on: April 17, 2006, 10:34:55 PM »
So I have the Grex running on a Mill :)
It is running well with the 1 KW servo motors that are on it with 2500PPR encoders and I am feeding pulses at 250,000 pps :) this is MUCH faster than Mach3... The drawing was done at 300IPM and the mill is about 3500 Lb with a 3Hp motor. Very nice for this little mill...
<a href="http://machsupport.com/forum/index.php?action=dlattach;topic=502.0;id=383" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://machsupport.com/forum/index.php?action=dlattach;topic=502.0;id=383</a>
[attachment deleted by admin]
« Last Edit: April 19, 2006, 06:23:07 PM by ynneb »
www.newfangledsolutions.com
www.machsupport.com
ynneb
Re: Got My mill running :)
« Reply #1 on: April 17, 2006, 11:27:17 PM »
Thats sweet movement. I am amazed at how smooth it is.
Thanks for posting the video Brian.
« Reply #2 on: April 18, 2006, 01:30:19 AM »
That is totally amazing.....
Well impressive !
« Reply #3 on: April 18, 2006, 06:36:15 PM »
I did a few more tests at 200IPM on some very small parts :) I can tell you that the newer version of Mach4 is going to do MUCH better! I am sitting down to draw out a test Gcode file for the Grex now and after that I will have a base for all the testing that I am going to be doing  8) As soon as i am done with the Gcode file I will post it here so you can test your Mach3 mills on it ...
www.machsupport.com
ynneb
« Reply #4 on: April 18, 2006, 06:41:31 PM »
Out of all the talk so far about Mach4 and Grex, this has caught my interest the most.
If a picture is worth a 1000 words, then how many words is a video at 30 fps for 2 minutes? :)
« Reply #5 on: April 18, 2006, 09:55:04 PM »
Brian,
How much torque do those servos put out? and at what speed?
Are the drives step and direction?
Regards
Fernando
« Reply #6 on: April 19, 2006, 07:00:42 AM »
They are max RPM of 3000 at about 5N-m (44.5 In-Lb) with a MAX 16N-m (133 In-Lb)
www.machsupport.com
Offline fdos
  •  326 326
« Reply #7 on: April 19, 2006, 03:29:46 PM »
Brian..  Are these the Automation direct servo's?
« Reply #8 on: April 19, 2006, 08:35:50 PM »
Yes they are  :o
www.machsupport.com
Offline fdos
  •  326 326
« Reply #9 on: April 20, 2006, 08:48:55 AM »
Yes they are  :o
Yes I vaguely recalled you said you had some to try...   I'm very interested in them myself as Servo systems seem to be very expnsive in comparison here in the UK. (We do tend to pay £1 per $ on some imported stuff)
Did you have rto buy all the items listed? ie leads, breakout, etc etc.
Wayne...
