Hello Guest it is October 13, 2026, 07:02:20 PM
Author Topic: E-stop VB script  (Read 56262 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
E-stop VB script
« on: June 06, 2006, 05:24:37 AM »
How do you trigger an event from the message ticker or the "active" on/off state of the emergency function(Estop).
I'd like to call on some type of event to trigger a "wave file script getter" for the active on/off state of the E-Stop.
If some one could help with the code then we can incorporate a wave file function to the estop. ;D
Here is the basic function code to call on a wave sound placed on a button:
Public Declare Function sndPlaySound Lib "winmm.dll" Alias "sndPlaySoundA" _
    (ByVal lpszSoundName As String, ByVal uFlags As Long) As Long
    sndPlaySound "C:\WINDOWS\MEDIA\ding.wav", &H1
Here is the code to place on the "Display" button(This is a two state button with two diffrent state sounds!)
value = GetParam("Boundry")
If  value = 1 Then
'SetButtonText " Job "
SetParam "Boundry" , 0
 Else
SetParam "Boundry" , 1
'SetButtonText "Machine"
sndPlaySound "C:\WINDOWS\MEDIA\tada.wav", &H1
End If
  Currently I haven't found the code to trigger a wave sound for the E-Stop, need some help
« Last Edit: June 06, 2006, 05:58:55 AM by zealouse »
Re: E-stop VB script
« Reply #1 on: June 06, 2006, 07:22:11 AM »
You are going to have to put that in the macropump... You can check the state of the Estop LED and if you see an estop run the script that you posted :)
That should get it working
www.newfangledsolutions.com
www.machsupport.com
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #2 on: June 06, 2006, 11:43:19 AM »
How do I create a macropump? Is it the (.M1s) ???
I feel that I must have missed a lot of valuable information about scripting in Mach. I've been looking around but can't find too much.
Where is the code for the Emergency function so I can check the state with a macropump?
Can I use something like this?
(b1) Inspect the input with a IsActive(ss) call in a Macropump
Mr.Barker,
Do you think there might be a better way to call on wave files?
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: June 06, 2006, 12:47:18 PM »
Okay, I'm alittle slow :P
Found tons of info on customizing.
http://www.machsupport.com/documentation/Customizing.pdf
« Reply #4 on: June 06, 2006, 12:51:27 PM »
This is a good way to play the wave files, The length on the macropump is not going to hurt the computer at all :)
To check the LED look in the Wiki at the LED codesHere: http://www.machsupport.com/MachCustomizeWiki/index.php?title=Standard_LEDs. once you have the code you can do this:
If(GetLED(0))Then
'Put your code here
end if
www.machsupport.com
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: June 06, 2006, 01:56:00 PM »
Does Mach load all macro's on start up? or how do I load a macro?
Would the Macro listen for the getLed(0) and play a wave file? so all the code would be place in the .M1s?
 or can I place VB code on LED's/Dro's?
Thanks for the help Mr.Barker
« Reply #6 on: June 06, 2006, 02:07:49 PM »
You need to save the macropump.m1s macro in the macros/mach3mill directory (if that is the profile that you are using) this is where the macro that you are going to put all your code into :) There is a video on the Macropump that I made some time ago...  The maco pump gets run a few time's a sec all the time! so take care in writing your macro!
There are many things to learn but you are getting there (you have good questions)
Brian
www.machsupport.com
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #7 on: June 06, 2006, 03:17:32 PM »
Okay now I'm getting some where,
I can use the Macropump.m1s
with:
but I'm getting a compiler error when I add:
If(GetLED(0))Then
end if
Is the (getLED(0)) declared by Mach3 or do I need to declare it?
I haven't seen the video, I'd like to ;D
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #8 on: June 06, 2006, 03:24:34 PM »
I would have thought it should look more like this
But I may be wrong as I use VB 2005
Graham
If(GetLED(0))Then
  sndPlaySound ()
end if
Public Declare Sub sndPlaySound Lib "winmm.dll" Alias "sndPlaySoundA" _
End Sub
« Last Edit: June 06, 2006, 03:30:26 PM by Graham Waterworth »
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #9 on: June 06, 2006, 06:49:14 PM »
Getting closer,
This code will work with the "physical Estop" but is not working with the Mach3 E-stop.
So when I engage my physical E-stop I get a sound responce, when I unengaged the sound stops like it should behave, but if the Mach 3 E-stop is still blinking or if I hit the softwear e-stop it will not give a sound responce.
What I think is I'm reaching the OEM code for the physical E-stop but not the virtual one. ???
Here is the code:
'Public Declare Function GetOEMLED (ledOEMCode As Integer) As Boolean
If GetOEMLed (19) Then
End If
'Else GetOEMLed (67) = 0
'sndPlaySound "C:\WINDOWS\MEDIA\tada.wav", &H1
'End If
