Hello Guest it is November 28, 2026, 06:28:59 AM
Author Topic: File selection dialog  (Read 27081 times)
« on: July 05, 2006, 10:50:57 AM »
In writing my wizard I need to be able to select a file for processing. I could make the user fill in a textbox but then with a textbox spelling counts and if they are like me  that is problametic (see what I mean).
Does anyone have a VB script to select a file ? Kind of like the one that appears when you load a G-Code file ?
I read the Enable documentation and being rusty to say the least at VB, I would sure appreciate any and all help.
Second Question:  - Is there a way to extract the text associated with a UserLabelXX ?
Thanks in advance.
Re: File selection dialog
« Reply #1 on: July 05, 2006, 08:10:53 PM »
There is no way to get the text form a label... :( and there is no way to browse for a file... I spent two nights trying to get that to work about a year ago :)
Sorry Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: August 07, 2006, 12:18:23 PM »
I guess you should not tell on old hacker (in the better sense of the term) that something can not be done  ;)
I have uploaded a file selection script for you to check out. It is not as nice as the one that Mach3 uses to select a g-code file but it works.
It saves the filename in the user variable area (I included the subroutine I use to get it back as well) so other routines can get to it.
The user variable area is GREAT.
Anyway - check it out and have fun  :)
« Reply #3 on: August 07, 2006, 01:37:47 PM »
Good job!
www.machsupport.com
