The only information on the control box is - CNC Depot Advanced Multi Axis Stepping Controller unit. The unit was supplied by Marchant Dice as part of a machine kit and the following is the info in their description. Maybe some of the UK members will have heard of them. I have just fired everything up again and noticed that the motors connected to the two axis that will not work are making a very faint buzzing noise but you have to listen very close up to hear it. Both these motors still work fine if cionnected to the Y axis terminal.
3 Axis Controller and stepper motors.
Parallel port to the PCB break out box with all connection marked.
3 axis modular High current design Driver 38V x 3.5A, (optional 4 axis, + £)
4 x motor output connector + 1 x Aux connection cable connector
350W ( 27V x 13A) switch mode high power supply
Special made dust free, splash proof Din connector with seal cap.
Selectable micro-stepping, 2,4,8,16,32,64,128,5,10,20,25,40,50,100,125
Selectable current: 1.3A,16.A,1.9A, 2.2A, 2.5A, 2.9A, 3.2A, 3.5A
All break out board and driver connection is Terminal block style. Easy
modification and wiring, schematic included.
High current switch mode power supply.
Dual dust filtered driver cooling fan
Front panel reset/emergency stop switch
Front panel power switch
Quality Compact Aluminum chassis, with bench feet.
All driver sinput are opto-isolated to the computer.
Stepper Motors
28V/3.5A, 1.8 Deg 192Oz/in torque high power dual shaft stepping motor.
Custom splash/dust proof din connector.
Dual shaft motor for optional encoder for DRO. ( we sell the match encoder) with pre-tapped 19mm x 2 M2.5 mounting hole.
