Hello
Guest
it is
August 31, 2024, 07:46:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
My machines shakes really bad when cutting a circle
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: My machines shakes really bad when cutting a circle (Read 5980 times)
Field Worker
5
on:
January 17, 2009, 03:52:11 PM »
I can feel the pulses in the concrete floor when I cut a circle out ( wood working CNC ).
The spindle shakes, the gantry shakes really hard.
I do not know what is causing this but what I hear is a loud pulse bang bang bang as it moves around.
Can anyone help pinpoint this to a problem?
It will do this even without a tool inserted.
Roger
Logged
Carnoustie, Scotland
Re: My machines shakes really bad when cutting a circle
Reply #1 on:
January 17, 2009, 04:00:18 PM »
Your code is likely to be made of many small segments rather than an arc. You may also be running in exact stop mode which will make it worse, constant velocity should improve things.
Logged
Field Worker
5
Reply #2 on:
January 17, 2009, 04:29:31 PM »
Thanks Hood for the quick reply.
Where do I go to change this?
Do I need to slow the stepper motor down on both drives?
Roger
Logged
Reply #3 on:
January 17, 2009, 04:51:42 PM »
CV is set on the Genral Config page , you get that from the Config menu.
Even if you have CV enabled code can still change it, so have a look in your code and see if there is a G61 at the beginning, if there is change it to a G64.
Logged
Field Worker
5
Reply #4 on:
January 17, 2009, 05:34:25 PM »
I'll try this out and let you know how it went.
Thanks again!
Roger
Logged
BluePinnacle
307
Reply #5 on:
January 21, 2009, 04:05:44 AM »
Odd, mine's ok, cuts nice small circles. What comands are you using for the circle? If as hood says it's a string of G01s then it would rattle between them with G61 on. G64 is the right medicine for curves.
Logged
Field Worker
5
Reply #6 on:
January 21, 2009, 09:04:09 AM »
Thanks for your reply Blue.
I tried what Hood said and it is smooth now. Before is was nasty. I Have another problem now, the ball screw for "Z" axis, the bearings inside are powder now or should I say in a paste form.
Soon I will have this totally rebuilt.
Logged
Print
Pages:
1
Go Up
« previous
next »
