Hello Guest it is January 15, 2025, 03:53:56 AM
Author Topic: Mach Components AGD  (Read 25212 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Mach Components AGD
« on: January 20, 2009, 07:49:03 AM »
Here is the beta release of the Mach Compontnets 1.0
Please post back feed back here or send me an email: support@alphagraphicdesigns.com
If you use them please help support future development by buying Pack2 from Alphagraphicdesigns.com.
Once they are available for purchase there will be a number of enhancements and additions.
**The beta version can only be used for hobbies and cannot be resold or distributed and are intended for evaluation purposes.
Video on how they work:
The video is here:
http://alphagraphicdesigns.com/help/Quantum/MachComponents1.0.1.wmv
Components (FLA):
http://alphagraphicdesigns.com/Download/MachCompontnes_beta_1.0.zip
Please also check out a fully developed screen from Mach Motion (components in action ;) ):
http://alphagraphicdesigns.com/machmotion/test/MM_demo.html
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach Components AGD
« Reply #1 on: January 26, 2009, 08:14:51 AM »
I have had a couple request for versions later then CS3.
Here is the location for users of MX2004 - Flash 8 otherwise if you are using CS2-CS4 download the above.
http://alphagraphicdesigns.com/Download/MachCompontnes_beta_1.0F8.zip
« Reply #2 on: April 01, 2010, 10:18:49 AM »
Hi, GREAT COMPONENT SET!!!!!
But i have a question about the gcode window. I place it on the stage with other objects (just to test some things) and load a .TAP file. I can see the code just fine. But if i navigate to the next frame, and then back to the first one... the code is gone  ???
Is their some actionscript i need to view the code again, once i move back to the gcode key frame?
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: April 01, 2010, 02:48:29 PM »
Yes that is true, you will need to have the Gcode on each page. You can place it off the "Stage" out of view.
I can update the Gcode so you don't have to do that, but will not be able to get to it till next month.
« Reply #4 on: April 01, 2010, 03:07:13 PM »
Thanx for the reply!
I will give it a try!
**UPDATE**
Yup, it worked fine, i will just hide it when not in use.  ;)
« Last Edit: April 01, 2010, 03:18:37 PM by billman311 »
« Reply #5 on: August 22, 2010, 06:12:35 PM »
I'm going to buy this just for the g-code window, but have a few questions first.
1) I can't seem to get more than 12 lines of g-code. It looks like the spacing is to great and the bottoms start to get cut off. Font Size doesn't seem to have any effect below 10-12 (not sure exactly). I've been playing with it for two hours, and every combination I came up with does basically the same thing. I'd like to squeeze 20-25 lines of code in the same space.
2) Is there an easier way to pick a background color? It's nearly impossible to pick white. And on a related note, what about greyscale? I wouldn't need white if I could pick a shade of grey.
Thanks, Jason.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #6 on: August 26, 2010, 11:26:01 AM »
Sorry for the delay, I attached a new Gcode component and test screen.
You can set the line number and spacing as well as select colors using a normal color picker.
« Last Edit: August 26, 2010, 11:33:29 AM by zealous »
« Reply #7 on: August 26, 2010, 11:42:27 AM »
Thanks, I'll try it tonight.
« Reply #8 on: August 26, 2010, 08:07:24 PM »
Jason, it won't open in CS3. Says "Unexpected file format".
« Reply #9 on: November 02, 2010, 07:14:37 PM »
bump
