Hello
Guest
it is
August 31, 2024, 07:30:50 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Plasma Application, Mach3 torch height control.
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
Go Down
Author
Topic: Plasma Application, Mach3 torch height control. (Read 164527 times)
walid_1988
1
Re: Plasma Application, Mach3 torch height control.
Reply #110 on:
April 15, 2014, 12:40:25 PM »
thanks
Logged
jacobgoona
6
Reply #111 on:
December 04, 2020, 04:21:19 PM »
OK stumbled upon this thread, since I am trying to fix one of my power supplies on my setup. I read somewhere else and heard the the bridge rectifier might have gone bad? Not sure if this is actually true, also dont know how they work.
Any ideas?
Logged
chipresistor122
7
Reply #112 on:
December 04, 2020, 04:29:29 PM »
Hey Jacob,
I can certainly help with that. So yes bridge rectifiers sometimes do go bad and they can cause power supplies to malfunction or just not work in general. Best thing to do is just replace the power supply or get a new bridge rectifier.
Logged
jacobgoona
6
Reply #113 on:
December 04, 2020, 04:37:47 PM »
Ok got it yea I think I might just try to replace the bridge rectifier then. i just still have no idea how it works. Do you know the basic functionality of it. Will help me understand more. Thanks
Logged
chipresistor122
7
Reply #114 on:
December 04, 2020, 04:41:11 PM »
Yea a bridge rectifier is essentially a configuration of 4 diodes. Its used to convert AC to DC . it allows current to flow in one direction and not backwards.
Logged
jacobgoona
6
Reply #115 on:
December 04, 2020, 04:44:37 PM »
Okay got it , 4 diodes.. Does it come in a kit and you have to put it together or something like that?
Logged
chipresistor122
7
Reply #116 on:
December 04, 2020, 04:54:34 PM »
Nope no kit, although in theory yes you could configure your own. Don't do that though. They come in pre-assembled modules. i found this it will help explain how they work so you have a better understanding
https://www.derf.com/how-a-bridge-rectifier-works-step-by-step-tutorial/
goes into detail about the process of rectification. Which is the first thing you should learn. It is the most basic principle when it comes to any type of rectifier. Full wave, half wave, three etc.. Also it talk about the different applications. Also you can google a lot of this. Tons of information out there.
Logged
jacobgoona
6
Reply #117 on:
December 04, 2020, 05:01:08 PM »
Hey thanks so much for detailed reply. Wow just looked on google tons of information. I will give that article a read to looks like a great resource. Thanks so much.
Logged
chipresistor122
7
Reply #118 on:
December 04, 2020, 05:07:19 PM »
Yup no problem, let me know if you have any other questions I am be happy to help.
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
Go Up
« previous
next »
