Hello Guest it is December 30, 2024, 12:30:05 PM
Author Topic: 4 axis in inches  (Read 7446 times)
4 axis in inches
« on: January 28, 2009, 09:00:36 PM »
Is there some way to have the 4th or A axis take inches insted of degrees?  I have 2 programs that I used V-carve to design and Bobcad-cam to convert to A but all it does is change the Y to A but the value is still in inches needless to say that does not get the job done.
Re: 4 axis in inches
« Reply #1 on: January 29, 2009, 07:00:08 AM »
Do a search under fourth axis or rotary table as the there are  posts worth reading. They provide specific info for manny different set ups.
Got to go,
Offline olf20
  •  325 325
« Reply #2 on: January 29, 2009, 07:36:20 AM »
Here is one discussion.
http://www.machsupport.com/forum/index.php/topic,5281.0.html
Hope this helps!
olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #3 on: February 01, 2009, 04:07:02 PM »
Hi
Same thing block pops up, no shuttle or buttons
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: February 01, 2009, 05:47:13 PM »
Hi, Sawdustman
Post some of your code, Dxf & G-code.
Hears a Test 4 th Axis done in BobCad ver. 23, It has A axis in Deg.'s, The Y axis is 3.1416 tall and "A axis setting"  is set to 1 inch.
Still fooling around with it Hear, Would like to look at your work, What ver of BobCad are you using.
Chip
« Last Edit: February 01, 2009, 06:54:00 PM by Chip »
Offline olf20
  •  325 325
« Reply #5 on: February 02, 2009, 07:01:20 AM »
Hi all,
Here is a thread over at Vectric's forum.
Some very interesting stuff.
http://www.vectric.com/forum/viewtopic.php?f=2&t=656
Hope this helps!!
olf20
« Reply #6 on: February 02, 2009, 11:21:59 AM »
Can't you just set the axis up as linear? I guess it would depend on how the code is written, but it may work.
« Reply #7 on: July 27, 2011, 01:38:42 AM »
You have to "do the math", but CNC Wrapper does a good job. What I mean by doing the math, is to first create a toolpath for your given project, such as a MeshCAM 3D carving, and open it into Mach3. Navigate to the toolpath window, and READ the Y Extents of the open G code. Next, close the G code file, and import it into CNC Wrapper. The surface circumference of the desired stock must be equal to the Y Extents you just read in Mach3's toolpath window. Follow the instructions in CNC Wrapper on how to do this, but the G code file it outputs can the be loaded into Mach3 and (once you have everything set up in Mach3 for a 4th axis machine) will carve the file onto a cylinder loaded into the 4th axis chuck. Works for me, but I am still learning....
