Hello Guest it is September 23, 2026, 01:07:30 AM
Author Topic: Need a THC beta tester please............  (Read 12539 times)
« on: February 16, 2009, 10:54:39 AM »
Greetings,
   I am doing a Plugin for a THC (Torch Height Control) OEM and Mach3.
I am in the East TN area close to Knoxville, and would like someone local who is building a Plazma table, and plans on using a Step/Dir Z drive for control. The Plazma unit that you are using or Planning to use MUST give off a 1-10V analog out put that represents the top and bottom voltage range at the Plazma working end.
The OEM is willing to donate to you the THC Hardware as part of the compensation for your help and trouble. BUT, you must supply a working 3 axis table, and Plazma cuttin unit that does the above.
Scott
Offline klmark
  •  107 107
Re: Need a THC beta tester please............
« Reply #1 on: February 16, 2009, 11:09:43 AM »
Hi
I got the table with what you look for I plan to add a plasma on there It currently A gas torch on it   But I am in South Dakota
  Klmark
vmax549
« Reply #2 on: February 16, 2009, 04:45:50 PM »
SCott I am workin on one down here in FLorida. But still a couple weeks away from having the table moving. Have to finish the cnc roll bender first(;-) IF I can be of any help let me know.
CNC you just gotta lov it, (;-) TP
« Reply #3 on: February 16, 2009, 07:43:19 PM »
do you have any daily experience running a Plazma table?
as far as location, sorry gotta be able to drive less than 1 hour to get to the site.........
scott
