Hello Guest it is November 25, 2026, 04:55:19 PM
Author Topic: DRO Issues Pls help  (Read 13418 times)
DRO Issues Pls help
« on: March 27, 2009, 08:44:32 AM »
Hi all I'm new here si please be gentle.  I have today finally got everything i need to get the motors rolling.  i have installed mach3 (licenced) on my computer (ibm thinkpad pentuim m 1.7g 512mb ram).  when i go to my quickstart preload, all is good for about 3 - 4 seconds.  If i toggle xy or z they move fine but then after the 3 or 4 seconds, everything seemd to stop.  if i hold down say the page down key, the z that momentarily had moved fine, will now only click step at a time (if that even).  I know it sounds like i am rambling, i am very new in the world of cnc.  I have tried to change motor speeds etc, but that doesn't fix anything.  the problem is present even if i press the tab key and shuttle with the mouse.
please help if you can.
thanks in advance
ben
Offline zarzul
  •  233 233
  • Wyoming, USA
Re: DRO Issues Pls help
« Reply #1 on: March 27, 2009, 09:14:04 AM »
What is "quick start preload"  ?   I am not familiar with that.
What are your motor speeds, steps/in, & accelleration settings?
Arnie
Offline zarzul
  •  233 233
  • Wyoming, USA
« Reply #2 on: March 27, 2009, 09:17:31 AM »
You might be in incremental jog mode.  The jog mode toggles between 3 settings, incremental, continious, and off.  incremental just moves a set amount for each press of the axis jog pushbutton.
