Hello Guest it is March 12, 2025, 07:21:29 AM
Author Topic: New PoKeys software  (Read 32525 times)
Offline borisz
  •  220 220
    • www.poscope.com
New PoKeys software
« on: April 05, 2009, 03:56:19 PM »
Hi to all!
New PoKeys software was iploaded to www.poscope.com.
New options/corrections:
- added up to 8x8matrix keyboard interface
- added up to 6 PWM outputs
- some bugs removed
best regards
Boris
Re: New PoKeys software
« Reply #1 on: April 24, 2009, 09:29:33 AM »
Hello,
Could someone explain me the difference between a POKEYS and a MODBUS device?
ok, POKEYS goes USB with FPGA, should be faster, with different Protocol...
But my question is rather MACH-wise. Any PRO-s and contra-s? reliability, configurability, speed, etc?
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #2 on: May 30, 2009, 09:58:09 AM »
Hi to all!
New PoKeys software and user manual was uploaded to www.poscope.com.
- Vista 64 supported
- addded PoKeys55 dimensions to user manual
best regards
Boris
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #3 on: June 10, 2009, 03:54:15 PM »
v 2.02 is out.
- Added better keyboards support
- added interface to set analog output
- some  bugs removed
You can download it on www.poscope.com
best regards
Boris
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #4 on: July 06, 2009, 03:32:02 PM »
v2.03 is out
Added matrix LCD interface
Improved incremental encoder interface
USer manual and protocol specifications updated.
regards
Boris
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #5 on: October 12, 2009, 07:08:40 PM »
V 2.07 is out
- added lock function to prevent reading configuration from third persons
- improved matrix keyboard handling
bug removed
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #6 on: October 22, 2009, 05:45:19 PM »
Hi!
Latest plugin release: http://www.poscope.com/product.php?pid=3
Added simple LCD, MPG and keys configuration choose PoPendant profile.
regards
Boris
« Reply #7 on: October 22, 2009, 09:48:06 PM »
it has the "Matrix Keyboard" interface as well.
scott
« Reply #8 on: October 28, 2009, 06:08:45 PM »
28OCT2009
New PoKeys Plugin version 7.0, you will need PoKeys Software Version of at least 2.0.7 to take advantage
of all the currently supported functions.
Added PWM spindle control.
PWM is configured from the PoKeys Cfg. dialog
screen, NOT the Ports/Pins under spindle. PWM will come out of Pin 22 on the pokeys.
You will need to use the PoKeys Software to configure PWM to Pin 22, and set the freq.
to 25 us (25 Micro Seconds), and enable Pin 22.
If you choose to use PWM, you will need to check the "Use PWM" check box on the PoKeys
plugin dialog config page. 25us = 0-40,000 hrtz from the pokeys.
Currently the plugiin now supports:
1). PWM Spindle control
2). 8x8 Matrix Keyboard
3). 32 bit Encoder support and Encoder mapping
4). LCD
5). Analog Spindle out
6). IO mapping to UserLEDs
Scott
« Reply #9 on: October 28, 2009, 06:24:53 PM »
Note:
Typo, change:
should read: 25us = 40,000 hrtz from the pokeys.
scott
