Hello Guest it is May 23, 2025, 02:32:32 AM
Author Topic: Mach3 Aqua  (Read 157016 times)
Re: Mach3 Aqua
« Reply #20 on: October 09, 2009, 07:50:42 PM »
Did you copy and enable the Brain's that are included in the zip file?
And, does it not work at all, or just when you first start Mach3?
Also, I just remembered, you may need to set up at least one of the pulley speed ranges for it to work correctly.
« Last Edit: October 09, 2009, 08:07:45 PM by ger21 »
Re: Mach3 Aqua
« Reply #21 on: October 09, 2009, 08:42:12 PM »
On the 'machine settings' page is it possible to get a 'goto zero' button put in?
Perhaps replace the 'G90.1' and the G91.1' buttons with 'goto zero' and 'ref all home'?
Timothy
Try this. :)
vintageracer
Re: Mach3 Aqua
« Reply #22 on: October 09, 2009, 09:41:47 PM »
All the brains have been installed and activated.
I've set up the pulley speed range when I first configured the machine and it work flawlessly.
The override works, both by typing in a number up to 200% and by grabbing the slide bar and moving it.
The button just doesn't change. It reads 'reset override' all the time.  ???
Not really a big deal.
Thanks very much for the custom screen.
Timothy
Re: Mach3 Aqua
« Reply #23 on: October 09, 2009, 09:57:01 PM »
When you click it, does it reset to 100%? But it doesn't change? Not sure why, because it works fine on all 3 of my PC's here.
vintageracer
Re: Mach3 Aqua
« Reply #24 on: October 09, 2009, 10:25:17 PM »
It's working now....
Looks like someone disabled all the brains after deciding to complete the installation of a pendant at a later date.
Turned the brains on and all is OK.
Timothy
« Last Edit: October 09, 2009, 10:28:01 PM by vintageracer »
Re: Mach3 Aqua
« Reply #25 on: October 10, 2009, 11:18:19 AM »
Version 1.04
Changed A axis scale to Rotation Diameter for 4 axis work. Should have always been this way. The A Scale button image is included if you want to change it back.
Removed Z axis Auto Zero button. Replaced with Go To Safe Z.
Added Flyout window for Ernie's Probing routines.
http://cnczone.com/forums/showthread.php?t=56079
I copied these from Ernie's modified Mach Blue screenset.
These can be accessed with the TAB key, or by clicking the Artsoft logo (for Bob and his touchscreen )
Also added a (very) short .pdf manual.
http://tinyurl.com/pz8az9
Can I get this file from other download site. I cannot download this file from your site. Thank
High Tech Key
Re: Mach3 Aqua
« Reply #26 on: October 10, 2009, 12:36:38 PM »
This doesn't work?
Re: Mach3 Aqua
« Reply #27 on: October 12, 2009, 10:23:53 AM »
This doesn't work?
Dear Sir
This link may be work. But our proxy server block this site. So, please upload from some other download site if it is possible. Thank.
High Tech Key
Offline GeorgeRace
  •  53 53
  • My Home Built Airplane
    • Race Consulting
Re: Mach3 Aqua
« Reply #28 on: October 21, 2009, 01:01:27 PM »
Hi There:
I really like the screens you built.  Are very professional, and everything seems to work as expected.
Thanks so very much,
George Race
Check out my home page
http://www.mrrace.com
Re: Mach3 Aqua
« Reply #29 on: October 21, 2009, 01:38:16 PM »
Glad you like them. Thanks. :)
