If you installed from the same download it could be corrupt, if different then its unlikely.
If you want to attch your xml I can have a look, you will find it in your Mach3 folder, if you are using the standard profile it will be called Mach3Mill.xml
You will need to copy it to your desktop then rename for the forum to accept it, suggest you call it deepakjankie.xml.
