Hello everybody!
I was just about to mill a couple of pcb's when I discover that in the latetest version of Mach, somewhere between 042.20 - 042.26,
the feed rate over ride stop to work after typing something in the MDI input. The red led that normally flash beside the FDO DRO stop to
flash as well and I have to restart Mach to get it work again.
But after downgrading to 042.20 it worked as it should again. Have anybody else got the same problem?
Is there any command to enable or disable the feed rate over ride?
Best regards
Roger
