Hello
Guest
it is
December 26, 2024, 10:55:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
changing between mm and inch
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: changing between mm and inch (Read 5391 times)
osman100
36
on:
April 13, 2009, 09:57:02 AM »
in mach 3 how can i change between mm and inches
Logged
Carnoustie, Scotland
Re: changing between mm and inch
Reply #1 on:
April 13, 2009, 09:59:31 AM »
G20 is inch G21 metric. If you mean to have the machine set up as default in one or the other then you can set that from Config menu then Units. You will then need to retune motors if you change it, best a=lso to restart Mach after the changes.
Logged
osman100
36
Reply #2 on:
April 13, 2009, 10:40:10 AM »
ok thanks
Logged
Print
Pages:
1
Go Up
« previous
next »
