Hi all,
I knew it's weekend, but I need urgent help.
I have set my plasma machine Z axis as follows:
Z limit switch is on the top. Soft Max limit is 0, and soft min limit is -100, Home neg. checked.
Safe Z is 50 in machine coordinates.
When I start Homing, Z axis goes up to the switch, then down and stops to the limit sw off. Soft limits button works.
But when i start cutting process, Z axis goes up, touch the limit switch and Mach3 resets!
It stops at line N0110, (see below) and It reports Limit sw error.
In SheetCam I use Plasma THC300-G31-Corner slow down. post
I'm confused about how to solve this problem, what is configured wrong, or why post processor generates N0110 line. Is it possible SheetCam knows about Z safe coordinate?
Miroslav
N0000 (Filename: 30kwProba1.tap)
N0010 (Post processor: Plasma THC300 - G31 - corner slowdown.post)
N0020 (Date: 16.4.2009)
N0030 G21 (Units: Metric)
N0040 G53 G90 G40
N0050 F1
N0060 S500
N0070 M666 (THC off)
N0080 (Part: 30kwProba1)
N0090 (Process: Plasma, 0, plasma 3mm)
N0100 M06 T1 (plasma 3mm)
N0110 G00 Z50.0000
N0120 X1011.3000 Y1378.2000
N0130 Z5.0000
