Hello
Guest
it is
December 26, 2024, 10:45:45 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
need help step per unit
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: need help step per unit (Read 14896 times)
elgammmmal
9
Re: need help step per unit
Reply #10 on:
May 08, 2009, 06:18:44 PM »
I've attach a picture of the pulley I'm using hope that can be help
thank you
Logged
Overloaded
4,922
Reply #11 on:
May 08, 2009, 06:29:16 PM »
Well all you need to do is measure the OD of the 2 pulleys then divide but that probably will not work well for accurate motion control.
What exactly are you building ?
Logged
elgammmmal
9
Reply #12 on:
May 08, 2009, 06:39:04 PM »
I'm building cnc router for woodworking and I did try to use timing pulley but it is not available in my town I'm form Egypt so if it important I may make an order by any on line store. sorry for my poor writing
Logged
Overloaded
4,922
Reply #13 on:
May 08, 2009, 07:21:43 PM »
Your writing is really quite good.
I'm sure you would have been dissapointed if you had used the smooth pulleys.
Good luck to you and post some pictures of your machine when you get it together.
RC
Logged
Print
Pages:
1
2
Go Up
« previous
next »
