The Cross
The brief was to make an ornate cross, 90mm high by 65mm wide with scrolly work in it..
I drew the base with Rhino to get us as far as a weight estimate then filled it in with tsplines for the curly wurly stuff
The Tsplines base geometry
A close up of the geometry layout
and the render.
Deskproto(64bit) made childs play of the 116mb mesh file...
then off to the mill.. roughing.. big ol block of wax
and after the rough out on three sides the final pass with a fine cutter
and finally the first cut is done, the two short arms..
here is a quick clip to keep you interested untill the next post
[video]http://www.youtube.com/watch?v=UY9RSIjCvJs[/video]
