Hello Guest it is September 22, 2026, 12:38:52 AM
Author Topic: Problem configuring NC Pod  (Read 74769 times)
Re: Problem configuring NC Pod
« Reply #10 on: May 11, 2009, 01:12:07 PM »
thanks for your advices.
There is "Deskpod.dll in C:\Mach3\PlugIns. Is that OK ?
If it does, it was automaticaly done by installing ncpod driver.
In "C:\Mach3\PlugIns\NC-Pod USB Drivers" there is ncpod.dll ; ncpod.sys and ncpod.ini
If I put ncpod.dll in C:\Mach3\PlugIns an error occur.
Regards
Freddy
« Reply #11 on: May 13, 2009, 04:11:43 PM »
Hello,
The communication between mach3 and NCPod is finaly OK !!
Now I have problem to setup motors.
Is the configuration below seems ok? (i don't know what pins to put in this array)
Regards
Freddy
