Hello Guest it is February 18, 2025, 05:29:44 PM
Author Topic: Change Rotary Direction??  (Read 5888 times)
« on: May 09, 2009, 01:33:24 PM »
I have a Taig DSLS 3000 that I need to change the rotary turn direction on. It turns clockwise and I need it to turn counterclockwise. I'm think this is done in the ports & pins dropdown but I can't find where. Any help appreciated!!! Many Thanks!!! Cas
Re: Change Rotary Direction??
« Reply #1 on: May 09, 2009, 02:12:49 PM »
You meaning reverse the direction of the A Axis? if so then go to Config menu then Homing and Limits and change the reverse setting to the opposite of what it is for the A Axis.
« Reply #2 on: May 09, 2009, 02:29:42 PM »
Thanks Hood!
              Thats what I needed to do. I'll go give it a shot.
Don't know what I'd do without ya!!!!   Cas
