Thanks Jeff, you are correct. When I originally posted, I didn't know that the smooth stepper plugin was causing my issues. When I tried to run program on another computer it worked fine. It took a couple of days to figure this out. I should mention that I had already moved my first two smooth steppers out to a couple of friends. I just recieved the third one when I found that the smooth stepper needed to be plugged in or run just regular pp.
thanks, Jim.
