Hello Guest it is December 21, 2024, 08:50:36 AM
Author Topic: Mach 3 compatibility questiion.  (Read 12689 times)
Re: Mach 3 compatibility questiion.
« Reply #10 on: May 20, 2009, 05:43:28 PM »
Here you go TP,
Go to config ports and pins input signals  in input signals stroll the to  THC UP and THC down  enable both enable Emulated then set a hotkey for up and down this will control your up and down with the keyboard hit apply and go to Mill Options check mark Allow THC UP/DOWN Control even if not in THC mode
vmax549
« Reply #11 on: May 20, 2009, 08:58:01 PM »
HIYA HOOD, Tried that but did not see where it affected the z position but I did not try it on a machine.
BUT that is not going to be effctive IF we cannot "control" the amount it moves up or down . When engraving moves of .001" are required to keep the engraved lines looking crisp.
SOmething along the lines of INC STEP jogging or an analog control will be needed. I THINK(;-)
The engraver he is talking about is an HPGL system that take the HPGL printer output direct from a GRAPHICS program and uses it to drive the engraver controller in realtime. SO those type adjustments xyz on the fly could be done in a realtime senario.
