Hello Guest it is November 26, 2026, 12:25:05 AM
Author Topic: scaling different axes for different speeds.  (Read 10044 times)
« on: August 15, 2006, 07:24:54 PM »
I've just upgraded my Taig mill with microproto's new dsls "servo" system which uses Mach 3 as the post processor. The biggest problem I have is with the different speeds of the x,y,z, and 4th axis. When I'm using the 4th axis, the angular motion of the 4th axis is much slower than the movement in the x direction. If I increase the speed, the cutter moves too fast through the material (wax). Is there a way to scale the speed of one axis without affecting the speed of the other axis?
Re: scaling different axes for different speeds.
« Reply #1 on: August 15, 2006, 08:12:56 PM »
Yup, set the Rad of the part on the Settings page
www.newfangledsolutions.com
www.machsupport.com
