rally.sport,
Putting the SS in a solid metal box would be shield and that shield would be considered 100%. If it were shielded
in say a fine metal mesh screen ( there are rough equations or quides on how open the mesh should be depending on what you want to do ) then that also may be appropriate ( but not as good ). You could also just put Al tape, overlap the seams, ( like the tape used to seal duct seams ) around the whole thing and that would shield it.
Now if the noise is being carried to it via wiring inside the the shield then your shield won't be worth much in that sense.
Define the source of noise / rf, contain or minimise it, shield as best you can, move the SS to it's owne or appropriate location ( like in the computer case ), Use the same ground for the 5v as the gound of the supplied 5v.
Sometimes there is logic to it all ,sometimes i just call it black magic ( because it worked and nobody can realy say why!
Just some thought's, no one stop solution for you,
