I have a Syil X4 Plus mill and am controlling it with Mach 3. I am using Featurecam to generate tool paths and then a postprocessor I found online to generate G-code. Here si my problem:
I clamped my material in my vise and then set the cutter at 0,0,0, then I zeroed the DRO in Mach 3. When I ran my program, the X axis is offset around .25" It runs fine in my featurecam simulation, but looks offset when I load the program into Mach 3. I ran the program anyway, and sure enough there is an offset. Is thhis a common problem? Do I need to change an offset somewhere in Mach 3? Any other suggestions?
Thanks!
