DROOL,
When you export from AutoCad you will get two layers because , can't turn off Layer O ( def??somthing )in Cad
and the text ,I'm guessing, is on a layer.If you select the layer in the Project infomation, that layer and all the
enties in it will highlight in the dispaly screen. Expand the chain, is there anything in it?, if not you can probably delete it.
I don't know what you did, so tuff to tell, take a look at the manual.
Post your DXF file.
