Hello Guest it is September 15, 2026, 10:35:15 AM
Author Topic: 555 Timer index pules widening/delay  (Read 10174 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« on: August 25, 2009, 05:48:45 PM »
Hi, Jim
On My Compact 5 Lathe the index disk is about 4.5" in Dia. with about a 5/8 " slot to allow Mach to have time to see the opto Puls.
You may be able to use your Index pulse output as it is and add a IC555 Timer to reset with a adjustable time delay, R1 Var. resistor.
Just A Thought Hear, Chip
Edit: the resistor value is 1K and cap is 0.1 uf. This seemed to be the best values.
pules widening
