Hello Guest it is October 02, 2026, 10:00:49 PM
Author Topic: The Laser Project.  (Read 3524545 times)
0 Members and 5 Guests are viewing this topic.
Re: The Laser Project.
« Reply #980 on: April 17, 2017, 12:22:33 PM »
Did you try to download and install it? I think it will allow you to play with it without a licence, but will put watermarks on your image.
« Reply #981 on: April 17, 2017, 02:50:03 PM »
http://prntscr.com/exkn5o
There are watermarks.
But when I try to press the launch, a window for entering the key pops up.
I can not try.
I can only buy and use immediately.
Maybe I'm doing something wrong?
  •  9,374 9,374
« Reply #982 on: April 18, 2017, 12:44:30 AM »
Hi Nikolaj,
PicLaser demo version can be downloaded from here http://www.piclaser.com/
Try it to see if it meets your needs.
« Reply #983 on: April 18, 2017, 05:12:15 AM »
I can not try.
After loading an image, select the Tutorial PDF button for instructions.
Dan,
The Encoder information is in the PicEngrave Pro 5 Help PDF.
Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
« Reply #984 on: April 20, 2017, 08:04:00 AM »
Hello everybody. Thanks for the links and help.
Two days of experiments gave nothing.
Picengrave PRO5 works so dramatically that my machine almost fell apart.
With the configuration and instructions, I figured out - after loading in MACH 3 the machine trembles tremendously.
Dotg - it turns out to be not so bad. He works abruptly, but engraves.
Maybe I have with the settings of parameters Mach 3 that something is wrong?
How to properly adjust the laser for the laser?
Its settings attached.
https://drive.google.com/drive/folders/0B2Yl5soaDkgmU0kzRUY2SXF2aVU?usp=sharing
Thank you !
« Last Edit: April 20, 2017, 08:09:23 AM by DeserEagle »
« Reply #985 on: April 20, 2017, 08:13:20 AM »
Hi Nikolaj,
Tweakie -  i found such a photo.  http://prntscr.com/eypaj9      Where can I get a postprocessor with that name   "Tweake M10-M11.dgp"   for Dotg?
« Reply #987 on: April 22, 2017, 07:22:48 AM »
Try selecting Insert G61/G64.
This is not the place for product support. Use the Contact & Links page on our web site.
Thanks.
Jeff
  •  9,374 9,374
« Reply #988 on: August 18, 2017, 03:38:36 AM »
I needed to engrave a number of assembled parts which were too deep to fit beneath my laser nozzle. The solution would be a time consuming disassembly and re-assembly of the items or modification to my laser lens system.
As the combined mirror / lens assemblies (usually fitted to the commercial laser machines) are cheap to buy (from China) I decided to give it a try. Making a small bracket to fit the new mirror / lens assembly to the machine (in place of the existing lens assembly) replacing my vertical laser beam with a horizontal laser beam and creating a new Mach3 profile to swap the Z axis with the Y axis everything worked beautifully.
There are safety issues with having a horizontal laser beam on an open frame machine and I have not yet worked out the best / most foolproof solution but I am working on it.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #989 on: August 18, 2017, 06:37:38 AM »
Nice work Tweak.  Safety issues aside, its not a bad solution to that problem.  Parts are indeed quite reasonable these days.
Art
