Hello Guest it is April 04, 2025, 07:55:37 PM
Author Topic: The Laser Project.  (Read 2069180 times)
  •  9,284 9,284
Re: The Laser Project.
« Reply #120 on: June 19, 2010, 07:08:29 AM »
Hi Dan,
Before and after, and this doesn't include all the latest stuff. Hope I don't ever have to shift it.   ;D ;D
« Reply #121 on: June 19, 2010, 08:50:35 AM »
That is becoming one MEAN machine, my friend-
Offline N4NV
  •  398 398
« Reply #122 on: June 19, 2010, 10:15:19 AM »
Were did you get the air pump?
Vince
  •  9,284 9,284
« Reply #123 on: June 19, 2010, 10:27:55 AM »
Hi Vince,
Bought the pump via eBay - there are lots of suppliers, this is just one of them  http://shop.ebay.co.uk/nihilist23/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Mine came in at GBP 23.50 inc postage from a UK source (cheaper direct from China but subject to import tax).
« Reply #124 on: June 19, 2010, 11:48:36 AM »
I like your creativity, Tweakie. Wonder what else you might bolt onto it next... ;)
Daniel
  •  9,284 9,284
« Reply #125 on: June 22, 2010, 11:51:14 AM »
Hey Guys,
More stuff - latest picture, taken this week.
Shows the new laser air assist pump and spindle VFD, stowage for spindle motor (when not in use) and change to laser current display - the rotary axis is only fitted occasionally and can't really be classed as 'bolted on'.
You guys must be getting fed up with this thread by now - I must think of something new  ;D
« Reply #126 on: June 22, 2010, 12:17:03 PM »
Fed up, SHMED up !
One of, if not the best build threads here.
Keep em' coming Tweak !
THANKS !
Russ
« Reply #127 on: June 22, 2010, 03:34:39 PM »
Fed up, SHMED up !
THANKS !
Russ
Couldn't have said it better myself.
Me-thinks Tweakies owner is really a machine  ;)
Awesome-
« Reply #128 on: June 22, 2010, 04:24:51 PM »
That might just be it Dave, as soon as it can do everything in the manufacturing realm it can then take over the world.....self replicate and all that stuff ! >:D
Spooky, Scary Tweakie.
Maybe he works for Dr. Evil ? ? ?    or should it be "Tweakie and the Brain" ?
  •  9,284 9,284
« Reply #129 on: June 23, 2010, 05:06:09 AM »
Thank you guys, you are most kind.
This project still has a way to run so, with your permission, I will continue to bore you with pictures of my progress - The adventures of Tweakie.
The next part of the project is to add some form of temperature control / monitoring and provide for an automatic shut down in the event of tube over temperature. I am currently only running the laser for relatively short periods of time and at low power settings whilst monitoring the temp rise with a handheld surface contact probe. I perhaps should admit that the forced air radiator I am using is a bit overkill and so far I have not yet recorded a temp rise above ambient. However an automatic system will enable longer operational periods of the tube without causing any anxiety and it just has to be done.
