No rigid tapping but we do SRT which uses the same code as rigid, G84. It is a canned cycle and works well. Requires a G80 to cancel. Just a note in most applications it also requires a macro call or an Mo1 allow allow a gear change from Hi to low and the same after the G80 to return to HI range.
Hope that helps, (;-) TP
