Hood,
Yes, I just mounted the home/limit switch at the x neg. end of it's travel. And in homing selected Home Neg. That works OK. I think the manual says either way is OK.
The Z switch is at Z pos. end.
So every thing will be X+ (soft limits X+0.2 to X+6.0) and Z- (Soft limits Z-0.2 to Z-2.8 )
For X, I had "Dir Low active" checked and X "Reversed" checked in Homing/ Limits.
They are now both unchecked. No difference. Like one reverses the other...anyway.
After loading several files, the x / y limit DRO's on the run screen don't resemble anything similar to the code.. machine OR part coords.
Both Z and X have + and - values. Are they supposed to be in Machine or Part coords ?
Everything else works perfectly...referencing, homing, jogging, slow zones to soft limits in all 4 directions.
R2.60 is in that particular lathe. Is that too old maybe ?
I guess what's weird is after clicking to resume, NO soft limits are tripped...ever.
Thanks Hood,
RC
