Hello Guest it is September 15, 2026, 03:03:23 PM
Author Topic: Homing direction (can you change it)?  (Read 9297 times)
« on: October 07, 2009, 04:01:03 AM »
I never set up the homing on my mill since once I mounted a vice on the table, it would crash the back of the vise into the machine if it tried to home it.  Been manually setting it up ever time I turn on the machine.  That's getting old and I'm doing alot of the same parts over and over.
Can I change the setup so when I try to home the machine it sends the table towards me (in the negative Y direction)?  X and Z homing isn't a problem.
Or do I need to modify my limit switch?
Re: Homing direction (can you change it)?
« Reply #1 on: October 07, 2009, 04:38:02 AM »
Config menu then Homing and limits and either check or uncheck the Reverse option.
