Hello Guest it is April 26, 2025, 05:12:25 AM
Author Topic: G76 Threading Wizard ?  (Read 15315 times)
Re: G76 Threading Wizard ?
« Reply #10 on: October 16, 2009, 05:30:01 AM »
So there are no misunderstandings i can produce most of the optional settings in my cam.
So the ones that i can produce with cam should i remove/blank those settings on the Turn Options page and let cam do it.
Or remove the optional settings from cam and let Turn Options do it.
What in your opinion would be the best way ?
Phil
« Reply #11 on: October 16, 2009, 05:39:38 AM »
No need to blank out, I have just looked and I have different settings in each of these places and they are ignored if my G76 has them in it.
« Reply #12 on: October 16, 2009, 08:31:09 AM »
Phil,
THREADING DEFAULTS:
Section 5.4.7.2 page 5-9 in the Using Mach 3Turn manual says that a default value will be used if a value in a G76  canned cycle is omitted by the post processor.
