Hello Guest it is December 26, 2024, 05:22:59 AM
Poll
Why do I have to start in x0 y0
one
1 (33.3%)
two
2 (66.7%)
Total Members Voted: 3
Author Topic: Starting the programm in x0 y0  (Read 10282 times)
« on: November 09, 2009, 03:44:21 PM »
How is it possible that I have to start my NC code from the working aerea x0 y0 point otherwise it is starts on a wrong position? Even if I start the programm with a G90 it does the same.
Re: Starting the programm in x0 y0
« Reply #1 on: November 09, 2009, 03:49:30 PM »
Not sure what you are asking but you can set the offset zero to any position you like on your table by pressing the zero button at each axis DRO.
« Reply #2 on: November 09, 2009, 04:19:19 PM »
I have to move the tool to the 0,0 point and then start the programm. If i start on an other location it takes that location as the 0,0 point. This happened after choosing my 0,0 point. I was Very supprized it happened.
« Reply #3 on: November 09, 2009, 04:52:58 PM »
Sounds like your code may have had another offset in it.
Offline rcrabb
  •  146 146
« Reply #4 on: November 09, 2009, 07:09:30 PM »
Not sure I understand the poll here
Ryan
« Reply #5 on: November 09, 2009, 08:48:15 PM »
I voted "one" because it looked lonely.  Is there a setting in Mach that could override the G90 and treat the gcode as if it were incremental?
Randy
« Reply #6 on: November 10, 2009, 03:10:16 AM »
Can I upload the code so that you can look at it?
« Reply #7 on: November 10, 2009, 03:31:18 AM »
yes, use the additional options  button on the reply page then click Choose to browse to your file and attach.
« Reply #8 on: November 10, 2009, 04:46:21 AM »
Here it is. I'm curious! Thanks in advance.
« Reply #9 on: November 10, 2009, 07:01:07 AM »
Can you also attach your xml please.
