Hello Guest it is September 09, 2026, 12:12:44 PM
Author Topic: tool display  (Read 38282 times)
Re: tool display
« Reply #20 on: November 27, 2009, 05:26:48 PM »
however it will only ever be as accurate as you can measure.
what do you mean by that?
I am meaning if you use the auto calc in Mach to set the steps per unit then it will only be as accurate as the measurements you put in when Mach is doing the calcs for you.
« Last Edit: November 27, 2009, 05:37:38 PM by Hood »
Re: tool display
« Reply #21 on: November 27, 2009, 05:34:25 PM »
ah gotcha! Ya im playing with that now.
Re: tool display
« Reply #22 on: November 27, 2009, 05:41:14 PM »
ok That is sweet! Now can I confiscate for backlash somehow?
Re: tool display
« Reply #23 on: November 27, 2009, 05:45:46 PM »
Yes, there is a backlash comp page from Config menu  and there is also a few settings  on General Configs page.
 I have never used Backlash Comp but if you do a search of the forum you will find some info, suggest you search with backlash  shuttle as your search words.
 There may even be something in the members docs part of the forum.
« Last Edit: November 27, 2009, 05:48:25 PM by Hood »
Re: tool display
« Reply #24 on: November 27, 2009, 05:49:04 PM »
 I have never used Backlash Comp but if you do a search of the forum you will find some info, suggest you search with backlash  shuttle accel as your search words.
All I can say is thank you very much for your help so far!! I only with you were my neighbor! LOL
Re: tool display
« Reply #25 on: November 27, 2009, 05:52:09 PM »
Well in a way I suppose we are all neighbours in this Internet age, whether thats a good or bad thing I dont know ;D
