Hello Guest it is October 10, 2026, 09:49:40 AM
Author Topic: Hi/Low Current  (Read 12458 times)
Hi/Low Current
« on: December 25, 2009, 04:52:23 AM »
Hi
Can someone help me ??
When I run Mach3, direct on the lpt, my motor control goes Hi/Low Current fine.
But when I use Smoothstep v 1.2 Hi/Low Current don’t run ????
I use the same setup in Output Signal (see the attach file)
When I change Active Low Status in the setup I can get the,[img]http://Hi/Low Current to change,
But I cannot get it to change automatically like when I run direct on my LPT port. ???
« Last Edit: December 26, 2009, 02:04:23 AM by cap232 »
Re: Hi/Low Current
« Reply #1 on: December 27, 2009, 03:30:55 AM »
Hi
I write to Greg Cary
And he quickly write back, that he need to add that feature to the SmoothStepper plugin.
And will try to do it this week
Thanks  Greg   :) :)
