Hello
Guest
it is
October 06, 2024, 09:19:15 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Spindle orientation
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Spindle orientation (Read 13315 times)
pabeader
13
Re: Spindle orientation
Reply #10 on:
September 22, 2006, 08:51:34 PM »
Here is example code that we use... This is from an AB CNC but the principals should apply just the same.
N5000 M38 <--- change to low gear
N5010 M04 S20 <---set slow speed
N5020 M06 T421 <----- offset 21 is the adjustment for position
N5030 G91 <--- set relative movement
N5040 G04F1 <---- pause for 1 second
N5050 G33 Z-.100 K.20 <--- threadcut for .20 + offest
N5060 M05 <--- stop motion
N5070 G01 Z.100 T400 <--- reset to starting position
M30 <----- rewind
Logged
Graham Waterworth
2,730
Yorkshire Dales, England
Reply #11 on:
September 23, 2006, 05:05:30 AM »
Hi pabeader,
this looks very interesting, I will give this a go when I have finished installing the new spindle motor and inverter.
Thanks for that.
Graham
Logged
Print
Pages:
1
2
Go Up
« previous
next »
