Hello Guest it is September 28, 2026, 07:46:22 PM
Author Topic: estop chargepump  (Read 12277 times)
estop chargepump
« on: January 14, 2010, 02:50:49 AM »
I need an output signal (hi/low not chargepump) when estop button pressed and released
is it possible in mach3
regards,
Nuri Erginer
Re: estop chargepump
« Reply #1 on: January 14, 2010, 03:38:58 AM »
Hi Nuri,
Yes it is. Use one of the enable outputs, say Eanable1.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: January 14, 2010, 09:04:07 AM »
Just remember Nuri that an output from the PC does not make an EStop. Generally speaking an EStop switch should remove power from things that move (by removing mains power from your motors power supply.) As Peter mentioned an enable signal from Mach is a good way to let your controller know that Mach is in an operation state; but you should not depend on that for an EStop.
Happy machining , Jeff Birt
« Reply #3 on: January 14, 2010, 11:30:43 AM »
Thanks alot for your answers
Nuri Erginer
« Reply #4 on: January 14, 2010, 04:43:14 PM »
Hi Jeff,
Thanks for the correction. I read it that Nuri was talking about pressing the Mach3 Reset button, rather than an external EStop button.
Cheers,
Peter.
Homann Designs
