Hello Guest it is April 26, 2025, 01:02:34 AM
Author Topic: Would like opinions on servo motor voltage and PS secondary in series  (Read 19540 times)
Re: Would like opinions on servo motor voltage and PS secondary in series
« Reply #20 on: January 23, 2010, 11:20:54 AM »
Simpson,
An analog voltmeter will, if anything, give you a more accurate reading of voltage on a PWM controller, as the analog meter movement will "filter" the response.
I would not expect to see any difference in "smoothness", unless the PWM frequency is very low.  Did you say you had a Minarik controller?  If so, I would expect it's probably using 120Hz, derived from rectifying the line frequency, as the PWM frequency.  A higher quality controller would likely use a higher frequency.  But there are also other factors, like I-R compensation, and the voltage and current feedback loops that can also affect smoothness.  I don't recall if any of these are adjustable on the Minarik or not.  A good PWM controller, well-matched to the motor, should be perfectly smooth, until you get down into very low RPMs, where the motor may start "cogging" due to commutation.  This is where BLDCs, excel.
« Reply #21 on: January 25, 2010, 09:56:12 AM »
Thanks for all of the replies. I have the info I need now and a fairly good understanding of the various relationships I was asking about and everything makes sense.
Just a matter now of finding time to do the testing . . . .
