Hello Guest it is December 26, 2024, 08:05:06 AM
Author Topic: What is a good probe to use with Mach?  (Read 15819 times)
Offline Mattw
  •  41 41
Re: What is a good probe to use with Mach?
« Reply #20 on: January 21, 2010, 04:43:22 PM »
Oooo, smoothstepper.  :o  I ran one of those for about 1 day and made the switch to parallel ports.  If you are familiar the smoothstepper "watchdog", as I'm sure you are, I can see how that would lead to lots of such problems.  Not that I'm questioning any of your Mach problems, which I fully plan to read up on, but I wonder if you'd have better luck on parallel ports.
« Reply #21 on: January 21, 2010, 06:16:31 PM »
Matt,
The SS has been responsible for relatively few problems, and things were no better with the PP.  If anything, worse.  The "Watchdog" has only kicked in a few times, usually as a side-effect of another problem.
