Hello Guest it is September 10, 2026, 05:11:58 PM
Author Topic: rolling to a new computer  (Read 13449 times)
« on: January 26, 2010, 11:35:26 AM »
Is there a set of files/folders, etc to copy from my existing PC to put on my new PC that I will be using Mach3 and LazyCam on?  Or can I just copy the entire directory?   I don't want to lose my stepper motor setup, limits, etc, licences, etc.   I am currently using XP, and the new computer is supposed to come with a dual install of either XP or Windows 7, so I plan on sticking with XP.  Is there anything else I need to calibrate, etc since the new computer will be a lot faster than the dinosaur I currently use.
Charlie
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: rolling to a new computer
« Reply #1 on: January 26, 2010, 11:44:52 AM »
Install Mach on your new PC and then copy over the profile you are using, i.e. myprofilename.xml and the macros folder for that profile.
Happy machining , Jeff Birt
« Reply #2 on: January 27, 2010, 11:00:05 AM »
Don't forget any custom/modified bitmaps if your screens have been modifiyes too.
JH
« Reply #3 on: February 01, 2010, 09:31:57 PM »
Hi.  I have the new computer started and have transfered the files.  The new computer did not have a built in parallel port so I have installed a 2 port EPP/ECP PCI card.   I can't seem to get it working through.
Under resources each port list two sets of address.   I have E800-807 and E480-487 on one of the ports and EC00 to EC07 and E880 - E887...
So what port am I suposed to use in the setup, It does not allow me to put in a range?
Charlie
« Reply #4 on: February 02, 2010, 01:19:41 AM »
E800 and EC00 will be the addresses, you can choose whichever you want for Port 1 and Port2, just have to connect the cables accordingly.
« Reply #5 on: February 02, 2010, 10:05:06 AM »
You will have to tell Mach3 the hardware address of the new ports 1 and 2.  The port numbers are the same, but the PCI address is what Mach needs to interface too.
Hope that helps,
JH
