Hello Guest it is September 20, 2026, 05:34:10 PM
Author Topic: Lathe Config  (Read 9120 times)
Offline Ken K
  •  11 11
Lathe Config
« on: February 07, 2010, 10:37:03 PM »
 I am running a Taig mill with  Mach3 mill, and it is running fine. I now have a CNC lathe, which I am running from the same control er, and stepper motors as the mill. The problem I am having is when I use Mach3 lathe the stepper motors only move the lathe X, and Z about 1/3 of the distance called for, in the code. The screen show it has move the distance called for. Any help for this problem?
Ken K
Offline Ken K
  •  11 11
Re: Lathe Config
« Reply #1 on: February 07, 2010, 11:54:58 PM »
 Found my problem, it was in the motor speed control.
Ken K
