Hello Guest it is December 26, 2024, 12:23:51 PM
Author Topic: Activating a physical LED with Pokeys from Mach  (Read 5529 times)
« on: March 01, 2010, 08:56:53 PM »
Greetings!
I recently involved with brains and what i want to do is this...
I want every time that a LED in Mach3 screen turns on,a LED on my panel goes on too.
I did make a brain in mach3.So far the only thing i achieved is to light up the ULED in the Pokeys screen inside Mach but
why the physical LED don't light up?
The LED is attached to pin 11 in Pokeys,the pin was defined as an output and in Pokeys configuration the Range starts from 1000
(ULED range 1-55 for output also).
Any ideas?
Re: Activating a physical LED with Pokeys from Mach
« Reply #1 on: March 04, 2010, 06:41:08 PM »
Finally i made it work after trial and error
Thanks anyway...
Offline N4NV
  •  398 398
« Reply #2 on: March 14, 2010, 11:02:55 PM »
How did you make it work?  Can you post your brain?  I would like to do the same thing.
Vince
« Reply #3 on: April 03, 2010, 02:11:18 AM »
Hi Vince here is the brain.
The 2nd block in the brain is for controlling jog override via modbus and a potentiometer.
Offline N4NV
  •  398 398
« Reply #4 on: April 04, 2010, 11:15:25 AM »
Thanks, I will give it a try.
Vince
