Hello Guest it is October 03, 2026, 06:12:09 PM
Author Topic: Tormach TTS Belleville Spring Washer Deflection (Not Force)  (Read 20105 times)
Offline tjhj
  •  26 26
« on: March 13, 2010, 12:04:40 PM »
Hi All,
After reading as much as I can, and reading through all of the thread
What The World's Been Waiting For - Yet Another Power Drawbar Design
http://www.machsupport.com/forum/index.php/topic,11826.0.html
An interesting discussion on how much tension force is needed.
But my big question is how much total deflection is needed?
If anyone is using a TTS ATC System, how much travel in the spring washers is needed to ensure a good tool release?
Thank you for your time,
TJ
Re: Tormach TTS Belleville Spring Washer Deflection (Not Force)
« Reply #1 on: March 13, 2010, 02:55:11 PM »
0.100" is plenty.  0.050" will do it in most cases.
Offline tjhj
  •  26 26
« Reply #2 on: March 14, 2010, 12:20:51 PM »
I guessed correct. Now that's just odd.
Thank you for your time.
TJ
« Reply #3 on: March 15, 2010, 02:45:04 PM »
Ray, did you ever post pictures of your final configuration?
Randy
« Reply #4 on: March 15, 2010, 08:38:15 PM »
Randy
Randy,
Not really.  I abandoned the Belleville drawbar, because it just wasn't practical to get enough tension to properly hold a tool in a collet.  For a while, I used an impact wrench drawbar, but HATED the racket, and the wear on the drawbar and socket, so I removed it after a few months.  My "final" approach is a stepper motor with planetary gear reducer.  This will provide MORE than enough torque (up to 75 ft-lbs!), and allow the drawbar to be loosened just a few turns (for Tormach-style holders), or unscrewed completely, under software control.  But, as I've just returned to work, following 19 months of unemployment, I have very little time to get out to the shop.....
« Reply #5 on: March 15, 2010, 09:37:48 PM »
Good on ya, Ray!  I hope to be in that position myself really soon now (17 months and counting of unemployment for me...)
I think yours is the first motor-driven drawbar that I've heard of.  Scott_M over on CNCZone has a new handlever-operated hydraulic-force-multiplier TTS drawbar, but of course the Tormach doesn't have a quill...
Randy
« Reply #6 on: March 15, 2010, 10:31:40 PM »
Very interesting.....
http://cnczone.com/forums/showthread.php?t=100231
Thanks Randy
« Reply #7 on: March 16, 2010, 09:19:22 AM »
Randy
Randy,
Yes, no quill makes it a LOT easier.  I wonder how that lever-operated one will wear with use.  There's a LOT of pressure on those little cams and levers.  It wouldn't surprise me if they wore and loosened up over time.  Very nice execution though!
