I have a situation which I think would benefit from a parallel port adaptor âTâ plug.
I would like to access different pins in the printer cable for use with other hardware without going to the breakout board on the machine. I have thought about using an A/B switch and jumping the switch on the pins I need from the added hardware printer cable to the printer cable from the breakout board. A âTâ plug adaptor at the PP at the computer would make it easier.
Is there such a plug available?
AJ
