Hello Guest it is March 13, 2025, 01:10:42 PM
Author Topic: machine keeps stopping  (Read 8183 times)
« on: March 24, 2010, 09:25:13 PM »
hello all,   I am new to cnc ,  I have a 20"x20" router and everything works great except the machine keeps stopping for no apparent reason,  I am using a rotozip for a router and it stops too.  everything restarts when i reset the estop on screen (no actual button) , restart the router , and hit "run" and she continues right on from where she stopped,  this is terribly inconvenient,  don't know what to do or where to start , and one more thing ,  in the diagnostic screen the m1++ is yellow but goes out when i manually engage the switch
HELP ME MISTER WIZZARD ! ???
Re: machine keeps stopping
« Reply #1 on: March 25, 2010, 04:06:11 AM »
Can you attach your xml please. Also how are your limit switches wired, ie normally closed and in series or?
« Reply #2 on: March 25, 2010, 01:28:43 PM »
here is my xml file ,  thank you for looking at it for me
« Reply #3 on: March 25, 2010, 03:01:00 PM »
How are your switches set up and are they Normally Open switches?
« Reply #4 on: March 25, 2010, 07:22:56 PM »
hello,  sorry for my ignorance ,  but i really don't know,  but if you tell me how to check i will do so.
« Reply #5 on: March 25, 2010, 08:31:02 PM »
Can you maybe take a couple of pictures of the limit switches and where they connect to the breakout board, maybe that will let us see how they are wired. From your xml it looks like you only have home switches set up so I am a bit confused but pics should hep :)
« Reply #6 on: March 25, 2010, 08:39:19 PM »
i will see if i can find my camera,  there are 5 switches total   one on each end of the x and y screws and one one the top of the z, don't know if they are limit or home , maybe 1 home for x and one home for y  and the other 3 are limit,  but i really don't know for sure. and i am assuming that the breakout board is in the control box? is that right?
« Reply #7 on: March 25, 2010, 09:01:49 PM »
Yes thats correct regards the breakout board.
In the xml however you only have X- limit enabled and X Home and Y Home.
