Hello
Guest
it is
December 26, 2024, 11:34:37 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Turn Eccentric Wizard
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Turn Eccentric Wizard (Read 18413 times)
cliveastro
71
Re: Turn Eccentric Wizard
Reply #10 on:
March 29, 2010, 02:50:21 PM »
Sounds like its back to 4 jaw chucks and dial gauges then.
Thanks for the inputs.
Clive
Logged
Graham Waterworth
2,747
Yorkshire Dales, England
Reply #11 on:
March 31, 2010, 08:41:44 AM »
You would need a lathe with a Y axis for a start so you could maintain the tool centre height.
Graham
Logged
Overloaded
4,922
Reply #12 on:
March 31, 2010, 08:54:51 AM »
Excellent point there Graham, I completely overlooked that aspect.
Logged
cliveastro
71
Reply #13 on:
March 31, 2010, 12:13:16 PM »
Very Good point I will definately stick to 4 jaw chuck
Clive
Logged
M250cnc
591
Reply #14 on:
March 31, 2010, 01:35:09 PM »
Looks like nobody watched the video posted by wantcnc
Phil
Logged
Dan13
1,208
Reply #15 on:
March 31, 2010, 01:46:29 PM »
I did Phil. It is so very impressive! I have no idea what it takes to make the gcode for this part...
Are there CAM packages that can handle such things?
Daniel
Logged
cliveastro
71
Reply #16 on:
March 31, 2010, 02:46:19 PM »
I did too.
Logged
Carnoustie, Scotland
Reply #17 on:
March 31, 2010, 02:52:55 PM »
Looks to me like the Mazak has a Y axis unless its just an optical illusion.
Logged
Graham Waterworth
2,747
Reply #18 on:
March 31, 2010, 03:15:45 PM »
Clive,
if its a repeat job bore a offset hole in a round billet and split it through the thick side then you can hold it in the three jaw.
Graham
Logged
cliveastro
71
Reply #19 on:
March 31, 2010, 03:26:26 PM »
Thats a very good idea Graham, but I was only being lazy.
I seem to speed ages setting up 4 jaw chucks
Clive
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
