I have been gone for 5 months and just got back to my CNC mill. Everything was working fine when I left, so I wasn't expecting any problems. Yea....sure
I fired up MACH and then powered up my controller. To my suprise, nothing worked. It took me an hour to realize that I had started MACH with the wrong XML. Duh!!!!!!!!
Great....restarted with the correct XML, powered up my controller and bingo...I heard the stepper motors "lock" in postion and I thought I was ready to go....again
This time, everything "seemed" OK, but, when I tried to jog, the DRO's advanced, but the stepper motors didn't move. This time I spent two hours pouring over the forum trying to find the answer. I knew that my ports and pins settings were OK because I had run the machine before with this XML (once I loaded the correct one
) I was just about convinced that I had somehow damaged the parallel port on my computer, but decided to reboot the computer one more time and suddenly everything started working perfectly.
At this point, I have no idea why it didn't work (when I used the correct XML) or why it started working again.
I'm happy it's working, but I'd like to know what was going on when the DRO's were moving but there was no axis movement.
Has anyone else ever run into this sort of situation? Do parallel ports just get "flaky" sometimes and then straighten themselves out?
Also, I read about a "parallel port test program" referred to in several threads. Where can I find that?
