Hello
Guest
it is
March 12, 2025, 12:31:47 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
edge find routine with mach screen sets on a pendant?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: edge find routine with mach screen sets on a pendant? (Read 9672 times)
eloid
33
on:
April 16, 2010, 11:37:01 PM »
was looking to make a pendant then i found this thread,
can some please let me know if this possible...
I like to make a pendant with pokey with a lcd and matrix key pad
like to make the keys programable to link with mach screen sets ie
I like to use hoss probing and corner finding fuction and also the pocketing routines
for find diameter of holes etc... and edge finding and z height setting
as seen here
http://www.cnczone.com/forums/showthread.php?t=56079&page=16
post 191
http://www.cnczone.com/forums/showthread.php?t=56079&page=15
post 177
is this possible?
Logged
borisz
220
Re: edge find routine with mach screen sets on a pendant?
Reply #1 on:
April 18, 2010, 06:24:04 AM »
Hi!
I did not checked links.
With PoKeys you can sense whatever you want. If you will use plugin, Pokeys is reporting to Mach whatever you set.
With a help of Brains, all is possible.
regards
Boris
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Print
Pages:
1
Go Up
« previous
next »
